High ratio or standard ratio steering rack?
Post by peakrock » Thu Aug 29, 2019 9:42 am
Is anyone able to comment on the drivability of the high ratio v standard ratio steering rack? I'm used to the standard rack in my Type 2 and find it ok but need to decide what to go for in my Type 3.
Re: High ratio or standard ratio steering rack?
Post by EricStarmer » Fri Aug 30, 2019 3:37 pm
I guess all the people with high ratio racks drove off the road :D
westendguzzi
Post by westendguzzi » Fri Aug 30, 2019 3:49 pm
I honestly think that if you can handle it with a high ratio rack, your tyre pressures will need to be far too high giving no grip in the wet.
Just sayin.
Post by EricStarmer » Fri Aug 30, 2019 4:27 pm
Hmmm - guess I had it backwards - I just discovered that a high ratio rack means that your steering is less sensitive, not more - makes sense when I think about it, which I obviously didn't before I posted the previous comment :) .
