Rust
Oli4
Rust
Post by Oli4 » Thu Mar 28, 2019 4:47 pm
Hello everyone!
Do you guys know a solution for extreme rust? If so, please let me know!
mvg, Oli4
edit: sorry i posted this post in the wrong category
Re: Rust
Post by Richard and Pat » Thu Mar 28, 2019 5:00 pm
Where is it Oli4?
If it is in a place where you can sand it off there are several ways of treating it.
If it is through the panel then new steel will probably need to be let in.
If you cannot reduce their size to suit this forum, can you send some pictures to me by private message?
All the best
Re: Rust
Post by Richard and Pat » Thu Mar 28, 2019 6:33 pm
Re post it Oli4
steveO
Re: Rust
Post by steveO » Thu Mar 28, 2019 9:06 pm
No help at all, but I found moving to Calgary in Canada the best solution as no rust at all ever!!!!!!!!!
Naval Jelly used to be pretty good, but many phosphate based rust converters will work and can be painted over if only surface rust.
Oily
Re: Rust
Post by Oily » Fri Mar 29, 2019 6:30 pm
*sits back and watches this thread with interest*
Oli4
Re: Rust
Post by Oli4 » Mon Apr 01, 2019 2:48 pm
Richard and Pat, it's mostly on the side pipes. It's mostly surface rust except on the end of the pipes.
Re: Rust
Post by Weg » Mon Apr 01, 2019 3:22 pm
‘Character’
Re: Rust
Post by Richard and Pat » Mon Apr 01, 2019 7:14 pm
Is the chrome pitted? If not or at lease not too badly pitted, Chrome polish and elbow grease should see something presentable.
steveO
Re: Rust
Post by steveO » Mon Apr 01, 2019 7:38 pm
000 wire wool and liquid chrome polish is about the best bet. its what the restorers use.
Good luck. If not heat resistant paint, but you would have to abrade the chrome surface for it to stick and then only a temporary measure.
Re: Rust
Post by frederick » Mon Apr 01, 2019 10:50 pm
Some powdercoaters offer a high temp ceramic coating in different metallics. The one I use has a “near chrome” that can be buffed to look like polished nickel. I’ve had it done on headers, cylinders, cylinder heads and even a commando fuel tank. Not cheap. Big plus on headers it insulates Very effectively so that they’re actually touchable couple minutes after shut down.
