wiper motor
wiper motor
Post by Richard and Pat » Wed Mar 20, 2019 9:30 pm
Advice on windscreen wiper motor location please, pictures too please.
Re: wiper motor
Post by Weg » Thu Mar 21, 2019 7:15 am
Under the bonnet.
Fit the wiper motor and actuators before fitting the body.
Re: wiper motor
Post by Richard and Pat » Thu Mar 21, 2019 8:45 am
Thank you Tony, I need to be clearer in my questions.
Regarding location I should have said at what angle or how does one define the angle of attachment under the bonnet on the lip below the windscreen?
Your photo will be a help as it looks as though the bolt holes are parallel to the screen horizontally.
Re: wiper motor
Post by Weg » Thu Mar 21, 2019 9:22 am
First picture was Florence.
This is Edith, just took the bonnet off specially to take another picture!
Note the strut to give more stability to the G/F mounting area.
Re: wiper motor
Post by Richard and Pat » Thu Mar 21, 2019 7:12 pm
Thank you for taking Edith's Bonnet off!
Re: wiper motor
Post by EricStarmer » Fri Mar 22, 2019 1:46 am
I think the main thing is to get the axis of the motor drive pointing in the same direction as the axes of the holes in the fiberglass for the wiper blade "spindles", which is pretty much guaranteed because the angle of the wiper support tab is designed to make this happen . I don't think the clock position of the motor is very important - just try and get the motor to a position where the hold down bolts are not too close to the edge of the tab. Then you just have to play around with the lengths of the two rods driving the wipers until everything seems to work properly, and in phase - easier said than done . Then when you switch on the wipers and watch the tab flex, it'll make your day :-)
I had to cut an inch or two off my wiper blades to stop them hitting the windscreen supports - I now have the shortest wipers I've ever seen.
Re: wiper motor
Post by Richard and Pat » Fri Mar 22, 2019 8:00 am
Thank you Eric.
Re: wiper motor
Post by Oleg » Fri Mar 22, 2019 2:52 pm
Oleg's installation. The only thing I would add is that you will find it useful for future access to cut a port in the top of the glove-box.
Re: wiper motor
Post by Richard and Pat » Fri Mar 22, 2019 8:06 pm
Thank you Paul, different again. Good rain gutters too.
