Rear brake disc
AndyR
Rear brake disc
Post by AndyR » Mon Apr 07, 2025 9:57 pm
New tyres all fitted and wheels back on. Great to have the Triking back on the road for this spectacular weather!!
Whilst re-fitting the back wheel I noticed that the rear brake pads are only connecting to part of the disc. There is no adjustment on the caliper holding plate to correct this. Any ideas?
Andy
Re: Rear brake disc
Post by Weg » Tue Apr 08, 2025 4:08 pm
Looks about right.
It's a rear brake, doesn't do much work anyway.
iant-s
Re: Rear brake disc
Post by iant-s » Sun Apr 13, 2025 8:47 pm
Only concern might be if there is a section of brake pad material not touching the disc. This would not wear down and so create a step in the friction material on both sides.
I welded the holes up in my brake-pkate and made new ones further in so all of my pads sweeps the disc.
CairAndros
Re: Rear brake disc
Post by CairAndros » Mon Apr 14, 2025 8:54 pm
Judging the space between Outer rim of the disc and the bridge of the caliper(I estimate it is 1 inch) the caliper is mounted to low on the mounting plate.
Therefore the brake pads did not touch the disc on the outer rim.
I would move the mounting holes to the correct distance so the pads fit correctly on the disc.
