T3 -- Retro-Fit Doors
Post by Weg » Thu Jan 16, 2025 6:48 pm
Following the complete success of building Clarissa, my 2 door Type 3(the brown one) in 22/23, I decided to fit doors to Edith (my blue T3) before putting her back on the market.
Clarissa started as a new-build with a bare metal chassis, easier to develop than stripping out an existing build and gave a blank canvas to get the design right.
The brief to myself was to give easy access/exit for Carol (and later myself) while retaining a flush body with no handles or hinges visible.
Bespoke hinges were developed which can now be replicated easily.
The picture shows all the chassis work finished and ready for the body to be bonded on with PU adhesive.
I’m keeping the BS French Blue colour although now would be the best time to do a colour change.
Re: 2 Door T3 -- Retro-Fit Doors
Post by Richard and Pat » Thu Jan 16, 2025 10:46 pm
Well done Tony, it is a magnificent job.
Wizzle
Post by Wizzle » Sun Jan 19, 2025 8:13 am
That’s excellent work!
Post by Richard and Pat » Sun Jan 19, 2025 8:56 am
Perhaps update your work on the triangulation please Tony?
Post by Weg » Tue Jan 21, 2025 10:22 am
Monday:- Body shell bonded on leaving doors hinged in out of the way, giving access to PU joint in doorway.
Tuesday:- Doors bonded into position. Short 'tracer' cuts previously done in shell to give accurate line for final cut with diamond tipped lmm disk.
Wednesday:- Cut out doors. (Pic to follow)
CairAndros
Post by CairAndros » Tue Jan 21, 2025 3:16 pm
Great job Tony,
It is so inspiring, maybe it could be an option for Alan.
Although it is fun to make it yourself
Post by Weg » Wed Jan 22, 2025 10:25 am
That went well.
Chapin1
Post by Chapin1 » Tue Feb 04, 2025 11:32 pm
Wow just what I need on my new T4 build. Could you post more detail on hinges and latches,
Mike C
Post by Weg » Wed Feb 05, 2025 5:49 pm
Hi Mike, good to see you on here.
Where are you in USA, I'll put a pin in the Triking World map if that's ok with you.
Saw your crate picture on fb, presume chassis is powder coated.
You will need to do a bit of welding, how are you fixed in your workshop?
I'll email you shortly then we can talk details.
Re: T3 -- Retro-Fit Doors
Post by Doverhay » Wed Feb 19, 2025 9:15 pm
Where have the pictures gone?
