quick disconnect steering wheel
Posted: Mon Feb 03, 2020 3:05 am
by Spaniard
I recently purchased a steering wheel quick disconnect hub from Amazon here in the US. I am very disappointed with the free play in the wheel. Of course I didn't discover this until after I cut welded and mounted the unit.
What kind of play are you guys finding on the quick disconnect unit that Triking sells? It looks to be a good quality unit. I don't think I can justify purchasing another unit if it has play in the wheel.
Any other advice / info would be much appreciated.
Re: quick disconnect steering wheel
Posted: Mon Feb 03, 2020 10:43 am
by Davyboy
Hi Ivan,
The Triking unit I have fitted has absolutely zero radial play. However, after a while I found it vibrated through some slight axial movement. This was easily overcome by drilling down the centre of the steering column and fitting a spring so it took up any play automatically.
Hope this has been of some help.
Posted: Mon Feb 03, 2020 7:58 pm
Hi Ivan, I have had my quick release for eight years and 14,000 miles with zero play in the wheel. However I have experienced a little play recently and discovered it was in the connector at the rack and it would not tighten any further until I removed it, cleaned it and applied a little copper grease. It was refitted with a socket with an Allen key end, an extension and a 1/4" drive ratchet whereupon it tightened perfectly and I am back to zero slack.
Posted: Tue Feb 04, 2020 5:09 pm
by westendguzzi
Mine, supplied by Al, has 1mm of play measured on the wheel rim. Nowt wrong with that.
With the standard flat steering wheel, I did find my gloved hands were too close to switches and cockpit roll so made up some 20mm ally spacers. Kept the indicator switch in the original position.
Posted: Tue Feb 04, 2020 7:22 pm
by Spaniard
Thanks for the info. I placed an order with Alan. Hopefully it doesn't get held up in US customs. We still have plenty of snow, about 50 cm, so I won't be driving it any time soon unless I can get it out on the local lake where some friends race their motorcycles on the ice.
Posted: Tue Feb 04, 2020 8:57 pm
Now that I would like a go at.
Posted: Tue Feb 04, 2020 9:10 pm
by EricStarmer
I have a hard time getting going on gravel - don't think I'd go anywhere on a frozen lake.....
