Very warm welcome to Philpot1 In West Yorks.
Happy times with Triking.
New member West Yorkshire.
Re: New member West Yorkshire.
Hi Tony. Thanks. Its taken 3 months for me to get on the forum as i had to go through Alan layzell. I sent numerous emails but i didn't get any replies
Welcome to the Forum Philpot1.
Let us know if you need any advice.
All the best.
Rich
All the best.
Rich
Hi, Richard & Pat. I have a type 2 Triking, the engine is off a 1995 Moto Guzzi California 1100 EFI & the o/s/f wheel bearings rumbling & needs replacing. Are they BMC mini wheel bearings? Also i have a leaking rear bevel drive, the leak is coming from the drive shaft end. Do you know what part number it is for the seal. I could only assume the rear bevel is off the same bike as the engine. any info is much appreciated. many thanks Phil
I cannot help with the bearings but there should be a number on them to use for ordering at a local bearing place. However Alan sells them at Triking so check your price before using the bearing shop.
If you trawl the internet for Moto Guzzi 1995 California parts list you will get the right item. Gutsibits will have them I imagine. Excellent service experienced with them.
Thanks guy's for the info
Simple point, the drive end should be higher than the bevel box end to minimise oil running forward.
