Just finished a T4 not happy with first gear it’s way to tall and with hills where I live Ill burn out the clutch. I used a 2016 Stelivo 1200 cc donor bike. The forward reverse transmission works great in reverse as its ratio is perfect . Wish forward was same as reverse ratio, anyone know if this transmission cans can be modified?
Michael
Gear ratio
Re: Gear ratio
You need the 15 inch rear wheel conversion from Triking. Its not cheap but will massively improve your car. Lowers the overall gearing and you can fit a car tyre which will be way better than a round profile bike tyre which drifts and follows every nuance of the tarmac. Also car tyres are way cheaper than bike tyres.
