Rear for light requirement for MSVA
gogboy
Post by gogboy » Wed Jan 28, 2026 10:25 pm
What is the situation regarding the fitting of a rear fog lamp to a Triking. Is it required?
It seems to me that they come under motorcycle rules and therefore do not need one BUT if one is fitted, it has be within spec as for IVA and will be tested accordingly.
So if I am correct, if you don’t have one fitted it won’t be part of the test.
Thanks.
Re: Rear for light requirement for MSVA
Post by Richard and Pat » Thu Jan 29, 2026 7:05 am
That is my experience at a very thorough MOT centre I use.
With previous Trikings I have used the 21W element of the Number plate lamp as the fog lamp. I don't have a fog lamp currently on the T4 and it has had two MOT's in my ownership without issue.
gogboy
Post by gogboy » Thu Jan 29, 2026 4:42 pm
Thanks Richard!
I take it that it also sailed through the MSVA test without a problem?
Thanks for signing me up to the Trifles newsletter.
Iolo
Post by Richard and Pat » Thu Jan 29, 2026 5:25 pm
Did you get the email and were you able to open it ok?
I will ask Mark just to be sure and let you know.
Post by iant-s » Thu Jan 29, 2026 5:27 pm
Not required for MSVA.
Post by Richard and Pat » Thu Jan 29, 2026 5:30 pm
There you go Iolo.
