Carc swingarm spindle locking ring
gogboy
Post by gogboy » Sun Dec 07, 2025 10:52 am
Special tool for setting the carc spindle locking ring.
Guzzi recommend setting at 10 nm but it requires a special tool.
Easy homemade one can be made using a cheap 30mm socket and an angle grinder and a bit of filing.
Mine is a bit function over form but does the job. Socket cost me £4-80. I know people will say, "do it by feel" but I always think if manufacturers give torque values, they do so for a reason.
Re: Carc swingarm spindle locking ring
Post by Richard and Pat » Mon Dec 08, 2025 7:16 am
Well done indeed sir! Are you going to share a picture please? [You may need to reduce the size of photo. If you didn't happen to know about that, instructions, should you need them are in the last Trifles newsletter sent out last week.] Please let me know your email via private message, if you would like one/didn't get one.
Last edited by Richard and Pat on Mon Dec 08, 2025 7:57 am, edited 1 time in total.
Post by Richard and Pat » Mon Dec 08, 2025 7:17 am
Did you overhaul the bearings in the knuckle and yoke. Mine were an advisory on the last MOT.
gogboy
Post by gogboy » Mon Dec 08, 2025 9:03 pm
Here's the photo.Not very pretty, but hey, it works and it was cheap to produce!!
Tool Small.jpeg (16.15 KiB) Viewed 5503 times
gogboy
Post by gogboy » Mon Dec 08, 2025 9:07 pm
Forgot to add, I replaced all the bearings and seals in the knuckle and also fitted new swing arm bearings. Copious amounts of grease of course!!!!!
