CARC bearings
CARC bearings
Good morning Trikingistas,
Has anyone renewed the bearings in the rear suspension on the CARC system The three point unit and the yoke?
I assume it is remove, knock out the bearings, replace worn parts, grease and replace in situ?
Re: CARC bearings
Hi Richard
Should be straightforward so long as not seized as I found, probably no grease on assembly.
I've a couple of photos I can send if useful.
David
David
Re: CARC bearings
Yes please David. Did you make new steel spacers?
Re: CARC bearings
Hi Richard
When you say the "steel spacer" is that the steel tube that the bolt goes through ? If so no, its hardened and ground. I've yet to extract the bearings hopefully tomorrow so will update progress.
Are you on FB I'll post photos there the file is too large here.
Re: CARC bearings
Yes, the Triking Owners club page and am on there myself.
Re: CARC bearings
Hi Richard
I have made a spacer as the other was worn and pitted. Made from 18mm dia tool steel. As the spacer only rotates back and forth I assume tool steel will be hard enough or do you think I should harden it ?
Re: CARC bearings
How hard was it to machine David? If you can mark it with a file then case hardening is the way to go.
Re: CARC bearings
Fine. I used HSS tool to face and part off, with no problems. Drilling the bolt hole very slowly with plenty of cutting fluid.
I’ll harden and temper as advised.
Re: CARC bearings
One of the tips on the Moto Guzzi owners club forum was to use water pump or outboard grease.
Re: CARC bearings
Ah right good idea.
