Wheel removal
riccardogale
Wheel removal
Post by riccardogale » Sun Feb 03, 2019 12:27 am
What is the trick to getting those stubborn center caps off the Type 1 wire wheels? They work on a tension spring and are always a bugger to remove!
Re: Wheel removal
Post by Richard and Pat » Sun Feb 03, 2019 8:26 am
Hi Riccardo,
Are you able to post a picture please? If you need to reduce the size of your picture and you don't already know, it explains a method in last December's newsletter. Did you get one OK?
