After some more advice please.......
Had a spoke break on my last outing and as I need wheel and tyre off to fix the spoke, I thought I would treat myself to new tyres.
On the front I have shortlisted Avon Safety Milage Mk2's or Metzler Block Ks - comments please.
The back is proving very difficult. Neither of the above do a 140/80/17 to fit the original Guzzi rear wheel I still have on the Triking and I can't seem to find anything apart from standard bike round profile tyres! I want a square profile tyre to put more rubber on the road like a sidecar tyre but no joy in this size. I even toyed with trying a car tyre but again can't find one in this size and not sure it will go on the bike rim anyway?
HELP PLEASE!!
Tyres
Re: Tyres
Good morning Andy, I found the investment made in a Triking rear wheel paid for itself in 12,000 miles. Bike tyres were in the hundreds and a car tyre 70 pounds.
On the front I use Mitas.
Re: Tyres
I agree guys that going for a car rear wheel would be sensible but unfortunately the cost is prohibitive.
I have a spoked Guzzi wheel which can't be exchanged and my swing arm has insufficient clearance (maybe because a Jackal was the donor bike?) and the cost of all this is huge! Also I am totally happy with the handling so far and am not planning on many long trips ( I can't afford the resultant divorce!!).
I'll look up the recommendations for fronts, thanks.
Anyone else kept the old rear wheel and have any ideas on tyres, please chip in.
Cheers
Andy
Cheers
Andy
Re: Tyres
Assuming you can get a car tyre that would fit your swing arm, would it be possible to get the hub from your existing wheel rebuilt with a car rim? I've no idea if it's economically viable, but perhaps the two companies might be a reasonable place to start?
https://turrinowheels.com/
http://pjhallewellengineering.co.uk/
Re: Tyres
This article has a good discussion on tyre choice related to sidecar outfits which is mostly applicable to our Trikings.
https://bmwmotorcycletech.info/misclsidecartech.htm
For my Triking, I went with Michelin Road Classics on the front as they have a flatter profile, more suited to classic bikes which generally don’t get cornered until the foot pegs scrape. At the lower tyre pressures we use on the Triking there is a decent contact patch so they would be worth a look. On this Triking I have the rear car tyre conversion so I can’t comment about the Michelins on that.
https://www.demon-tweeks.com/uk/micheli ... e-2014990/
