Nr.100
Post
by Nr.100 » Tue Jan 08, 2019 10:28 am
Need your help.
I swapped the hagon shocks for progressive konis. The driving comfort has become much better but when cornering the triking
tilts a lot.
Does anyone have the best lengths of the shocks and the spring rate for a good or result or an idea for a stabi
Joachim
Post
by Weg » Tue Jan 08, 2019 2:17 pm
May be worth checking the tracking, 3mm toe in seems to be about right.
The standard Hagons are 280mm long, what length are yours and is the pre-load & damping adjustable?
Nr.100
Post
by Nr.100 » Thu Jan 10, 2019 10:23 am
Thank`s for your answer.
my Koni shocks are 309mm long for a little more space .
i have lineare springs with 40 kg rate , to hard for normal road.
and progressive springs with 28-56 kg rate perfect on road to soft in curves.
the shocks has 3 steps pre-load and 4 steps damping adjust.
i drive with soft damping and more pre- load on the driver side.
the rear shocks are 329mm with progressive springs ( orginal Guzzi)
