Cali 3 rear brake rotor
Can anyone tell me what the PCD of the 5 rear brake rotor fixing bolts are? It’s a difficult one to measure accurately, I’ve come up with either 110mm or 112mm but I need to be accurate to find a replacement.
Re: Cali 3 rear brake rotor
Have you tried the Guzzi Owners club on FB Richard?
Al says it’s 112mm, I’m going to remove the rotor and check the alignment before going any further. The rotor I have is quite a thick one so it’s not likely to be buckled but may need refacing.
