T1 850 glowing pipe
T1 850 glowing pipe
Post by Richard and Pat » Wed Feb 15, 2023 11:07 am
Good morning, or it would be if I could work out why one exhaust pipe [off-side] on my pals 850, points model 1978 Guzzi is glowing red. Alarmingly so. Any help appreciated please.
Tribus
Re: T1 850 glowing pipe
Post by Tribus » Thu Feb 16, 2023 6:55 am
Ignition timing out?
Fuel mixture too lean?
Fouled exhaust valve?
Restricted exhaust pipe?
Good luck with the problem
Post by Throwley » Thu Feb 16, 2023 8:22 am
Has he timed the ignition on the right side, then forgotten to time the left hand side individually? Easily done!
Post by Weg » Thu Feb 16, 2023 10:15 am
Has the engine been recently stripped, is the cam timing wrong on R/H side?
