I'm hoping someone might have a solution to my current problem; the front engine mount bolt from the donor Cali is well and truly struck fast! I resorted to chopping the frame away to extract the engine from the donor but now have to find a way of removing it... All the 'release' sprays I've use have made no impact at all. Heat from a mapp gas torch has failed too. I think I have three options left:
- drill the bolt out - but would this work considering it's corroded at both ends?
- take the casting off the engine and put it in the oven for an hour or two and then get physical
- admit defeat and get it spark eroded out
Do any of these stand a chance of success? Or does anyone have a suggestion that I haven't thought of?
Any and all thoughts/suggestions very welcome!
Stuck Engine Mounting Bolt
Re: Stuck Engine Mounting Bolt
If you have room use reverse drill (counterclockwise) drill bits starting small and working up almost until you get to the threads. Soak with penetrating oil and pick the leftover bits out with a dentil type pick. Finish with the correct sized tap. Your mileage may vary.
Can you weld a crossbar on the end of the engine bolt? The heat would help and the crossbar would give some purchase. This has been used by Frank the editor of a Classic magazine to good effect: https://www.soudal.co.uk/pro/products/c ... degrip-all
I had the same problem when stripping my EV Cali. The bolt is being physically gripped by aluminium oxide from the engine and zinc oxide from the bolt. The two white powders really like each other and fill all the space on an almost molecular level leading to an enormously strong hold, as you will already know.
Because my bike was still in one piece what I did was set a long spanner on the bolt head then, using wooden blocks, rig the entire weight of the bike so it was pushing on the spanner. Left it like that and soaked it with diesel for a couple of days with no effect at all.
Then did more research and found the only way to move the bolt was heat. You need to expand the aluminium casting to make room around the bolt shank. Two blowlamps and my Son leaning on the bike to increase the rotational force. Don't use MAPP gas - the flame is hot enough to melt aluminium. You want to get heat into the casting lugs without worrying about melting the aluminium. I had to be pretty bold but after some vigorous heating for 20 minutes the bike front wheel suddenly hit the floor as the bolt rotated. As soon as it had let go the white powder piled out when we maintained the heat level and continued to strongly wiggle the (by now very hot) spanner.
Do not hammer the end of the bolt, you will just burr it over and/or break the lug off the casting.
Your engine being out of the bike means it might be difficult to hold it still whilst you are wrestling and mauling the job. 2 propane blowlamps, big gloves and a bold attitude. Hope this helps.
Hi Ian,
Thanks for sharing your experience, I've come to the same conclusion as you did. Unfortunately my bolt doesn't have a head on it now - a combination of a rattle gun and my son getting a bit too physical with a breaker bar! I guess I'll need to weld a suitable nut onto the shaft.
I'm contemplating taking the ali casting off the engine and putting it in the kitchen oven for a couple of hours to get it heated through. I'm not sure though if this is a good idea as the casting will not be supported when trying to work the bolt free. At a guess, how hot do you think you got the casting when it released?
Thanks,
Thanks,
Have done this a couple of times on old Guzzis. It's a horrible job. Heat is your friend, as described before - do not start thwacking the bar, it doesn't end well.
This is a common problem on old Guzzis, part of my maintenance schedule is to remove, clean lug holes and bar, polish and refit with plenty of sticky grease. I do the same on the Triking. I wouldn't want to get a stuck one ever again.
Hi, Sorry I missed this question, If its not too late and depending on how far you have got with it.........
We have done dozens like this and has proved the quickest and easiest............
The best way to remove the engine bolt from the (bike) frame assuming you have tried all the usual methods and can't rotate or undo it.
Cut the head off the bolt, Drive a wedge/crowbar between the block and bike frame just enough to spread the frame lug away from the block by about 3mm, Use a 1mm cutting/slitting disc in an angle grinder to cut the bolt as flush with the block as possible, Remove wedge and repeat on opposite side, The engine can now be removed normally. Of course if the frame is to be discarded the frame lug can simply be cut off. Once the engine is out remove the front cover and use a press to push out the remains of the bolt, the casing can be warmed around the bolt which will help, sometimes it is necessary to push the bolt first one direction then the other until there is enough movement for it to come completely out without risk of damage to the case. DO NOT us excessive force (BIG hammer etc) on the end of the bolt either at this stage or when in the frame - I have seen a lot of cracked cases caused by this and they are often beyond economic repair. This may seem like extra work but it isn't really as in most cases / older engines etc its usually a good idea to remove the front cover anyway to check the timing chain and front oil seal.
We can do the press out job - usually pretty quick turnaround on loose covers if they are sent to us.
