Starting
Re: Starting
That's a good question---!
As with most cars, except some vintage vehicles, it goes like this.
Sit in drivers seat.
Ensure gearbox is in neutral
set handbrake
Pull out the choke
Turn ignition key to start while possibly opening throttle a little.
Release starter switch to run position.
Return choke when running steady.
xxxxxxxxxxxxxxxxxxxxxxxxxxx
Before doing that, if the car has been standing for 15years, some preparation would be wise.
Drain fuel tank and flush out.
Strip and clean carburetters
Clean plugs
Renew engine oil and filter, cleaning sump and coarse filter.
Renew battery as the old one will probably be dead.
Be in a well ventilated area
Ensure fire extinguisher is serviced and ready for action.
Put fresh petrol in tank
Good luck
set handbrake
Pull out the choke
Clean plugs
Good luck
Re: Starting
Check for fuel leaks after new fuel goes in
Pump tires to correct setting
Make sure brakes work and change fluid by bleeding ASAP
Check clutch disengages before starting to drive by pushing with engine off
Fuses might need a clean.
Good luck and let us know.
