Rear Tyre Size
Re: Rear Tyre Size
Post by EricStarmer » Sat Feb 15, 2020 11:41 pm
Thanks, Ivan, that's good to know.
Re: Rear Tyre Size
Post by EricStarmer » Mon Feb 17, 2020 4:42 pm
Ivan - what pressure do you use in your rear tyre ?
Re: Rear Tyre Size
Post by Spaniard » Mon Feb 17, 2020 7:07 pm
I don’t remember off the top of my head but I think it was on the higher side or recommended pressure. Probably mid to high 30s psi. The smaller diameter wheel should help with starts from a dead stop. The reason I go with higher pressures is because of the soft side wall. Haven’t had any grip issues with it wet or dry. Now brakes in the wet, that’s a different story.
Re: Rear Tyre Size
Post by EricStarmer » Tue Feb 18, 2020 4:01 pm
Thanks, Ivan.
Re: Rear Tyre Size
Post by Richard and Pat » Tue Feb 18, 2020 6:00 pm
Rear 30 PSI
Front 16 PSI
Re: Rear Tyre Size
Post by EricStarmer » Wed Feb 19, 2020 1:55 am
Thanks, Richard.
