Oil cooler hose fitting size?
colinc
Post by colinc » Sun May 10, 2020 10:13 am
Hi there,
Does anyone out there know what size the fittings are on the oil cooler hoses. I’ve read there are various available and they are notoriously difficult to determine type by simple measurements.
Would take the guess work out of it if someone already knows!
Thank you
Re: Oil cooler hose fitting size?
Post by Richard and Pat » Tue May 12, 2020 10:05 am
Hi Colinc,
If you have Fadebook [sic] try a question on there too see which comes back quickly. Sorry I cannot help myself only T3 here. https://www.facebook.com/groups/156599248504621/
jtdesign
Post by jtdesign » Tue May 12, 2020 11:26 am
Hi Colin,
'Scuse the vagueness but it is a while since I plumbed in the oil cooler. I seem to remember that the Guzzi pipe fitting was an unobtainable size, but the adaptors screwed into the cooler were a standard thread so I replaced the adaptors with standard AN adapters and used the self-assembly AN fittings and pipe. -6 or -8 would be an appropriate size. Choose the pipe carefully because the oil temps can be quite high on the 8V engines.
John
colinc
Post by colinc » Wed May 13, 2020 8:29 am
Thanks a John. What you said makes complete sense. Much appreciated
Post by Richard and Pat » Wed May 13, 2020 9:11 am
Richard and Pat wrote: ↑
Hi Colinc,
If you have Fadebook [sic] try a question on there too, to see which comes back quickest. Sorry I cannot help myself only T3 here. https://www.facebook.com/groups/156599248504621/
