Fuses and Relays advice please
I am looking at the wiring now and need to obtain a fuse box and relay holder/ individual relays. Ideas and recommendations please?
I am planning FUSES for:
Horns [Pair]
Horn [Oojahh]
Lights Right
Lights Left
Indicators
Windscreen wipers
Windscreen washer pump
Ignition / starter?
Fuel Pump
Cigar lighter/ 12v supply
Aux supply
RELAYS for:
Starter
Horns 1
Horn 2
Lights L
Lights R
Brake lights
The two relays that come with the bike serve which function please?
Horns [Pair]
Horn [Oojahh]
Lights Right
Lights Left
Indicators
Windscreen wipers
Ignition / starter?
Fuel Pump
Aux supply
RELAYS for:
Starter
Horns 1
Horn 2
Lights L
Lights R
Brake lights
Re: Fuses and Relays advice please
Starter and horns on my current Guzzi, Richard, and on every Big Block I've ever owned.
AES do a whole range of fuse boxes and mini relays that will cover everything you will need.
https://www.autoelectricsupplies.co.uk/
Rule No.1
Don't put everything through one fuse!
Rule No.1
And Vehicle Wiring Products offer a modular system of fuse and relay boards which can be used singly, in attached pairs or clip together into one lidded box which could neaten things up a bit.
https://motogadget.com/shop/de/m-unit-blue.html
Or keeless and with an app for your smartphone
Wow, that is technical.
Thank you
Thank you
Thank you to those who have replied. Am I missing any fuses or Relays?
Charging circuit, regulator to battery. 30a.
I second the Moto Gadget unit. I installed one and am very happy with it.
