Hagon shock absorber spring weights
Post by iant-s » Fri Jun 21, 2024 5:17 pm
Having given my side panniers their first outing to Telford, I have observed that the additional 15kg per side is compressing my front suspension more than I am happy with. With 2 people, the kit under the bonnet and 30kg the original Triking supplied Hagon stainless steel shock absorbers have only 20 or 30mm free travel left. This is with the pre-load collars at the middle setting. I set them to the highest pre-load and the suspension upper wishbone is now level with the road, so I am happy with that for now but I would like the shocks to be at middle so I have pre-load adjustment up and down.
Onto questions then;
1. What is the spring weight I have fitted?
2. What spring weights are available?
3. Would 12mm thick spacer collars to add pre-load to my existing springs provide sufficient extra spring weight?
4. Would a change to the latest Nitron units fitted with a suitable spring weight be a superior solution?
Your thoughts and advice appreciated.
Re: Hagon shock absorber spring weights
Post by Weg » Tue Jun 25, 2024 8:29 am
Hi Ian,
Don't know much about basic shocker spring rates.
The Hagon Nitro "Comfort" option front suspension is a far superior fitment, giving full range of adjustment for comfort to suit your driving style.
It will need new bottom and top wishbones to accomodate the longer shockers making total job a bit pricey, but well worth the investment.
Post by iant-s » Fri Sep 05, 2025 8:58 am
I now have the High performance suspension conversion on my car. The front has achieved everything I could want, however the rear is taking more setting up.
Alan has supplied 20kg springs ( engraved 20 on spring coil bottoms ) but I am bottoming out when 2 people on board. I am using 10mm pre-load to level the car and 1 turn of damping.
Has anyone else got this suspension and what settings are you using?
Post by iant-s » Fri Sep 12, 2025 8:15 am
UPDATE
Have now fitted 23kg springs in place of the 20kg ones. A profound difference for what sounds like a small change. The car now floats on its springs and uses about 15 to 20mm of travel with just the car weight instead of 40 to 50mm. We are almost always carrying a Passenger
Note that my car is perhaps a little heavier on the tail as I have a steel mudguard, an extension steel box for storage and carry a scissor jack.
