Hi All
Just joined the group after picking up a Type 1 a couple of weeks ago. She needs a complete rebuild, engine not a problem for me as served my time in the motorcycle industry as a motorcycle engineering.
Now the questions.
I presume the front suspension top bolts should be 1/2" with a UNF thread and not 12mm threaded bar one side and 1/2" threaded bar the other size.
Lower engine bolts Metric as the Guzzi Motor is all metric, again threaded rod has been used.
One other question regarding the rear wheel clearence, I have a 15" spoke wheel with car tyre fitted, the clearance is very tight to the rear body cover 1/4" is this enough?
Look forward to some answers so many thanks
Regards
Mike
Type 1 Thread sizes
Re: Type 1 Thread sizes
I have copied your post onto our Facebook page for additional coverage Mike.
From Axel in Germany answered on Fadebook [sic]:
Axel Scheuten
You are right, all four suspension bolts are 1/2“ UNF, all engine bolts are metric.
Axel Scheuten
The wishbone bushes are Lotus type, the bearing on top are from a Triumph Spitfire, the lower one‘s are Reliant Kitten, but no longer available. If they are worn out, send them to Alan, he can repair them.
Axel Scheuten
Axel Scheuten
