Laser/waterjet cutting and small fabrication supplier?
Post by Throwley » Tue May 18, 2021 11:17 am
I need to make a steering wheel adaptor plate in 5mm alloy (commercial grade is OK), it's a simple flat plate with plain bores at two set PCDs, nothing fancy. There's a whole slew of small fab. companies out there who do lasercutting or waterjet by post; can anyone narrow the field down by recommending one, please?
Re: Laser/waterjet cutting and small fabrication supplier?
Post by Alanla » Thu Jun 03, 2021 10:17 am
Hi, We use Wrightform in Eye Suffolk and C3 in Derham (Norfolk) also Laserfast near Kings Lynn are pretty helpfull, These are local to us but I am sure they would post a small part anywhere. If its a small machining / fabrication job we could probably do it here economically.... Let us know if you get stuck.
Alan
Post by Throwley » Mon Jun 07, 2021 10:32 am
Hi Alan.
Thanks for the suggestions, duly notebooked :-)
I ended up taking the cheaper option of getting a stock lasercut blank and finishing it myself.
