Rear Tyre Size
Re: Rear Tyre Size
Thanks, Ivan, that's good to know.
Re: Rear Tyre Size
Ivan - what pressure do you use in your rear tyre ?
Re: Rear Tyre Size
I don’t remember off the top of my head but I think it was on the higher side or recommended pressure. Probably mid to high 30s psi. The smaller diameter wheel should help with starts from a dead stop. The reason I go with higher pressures is because of the soft side wall. Haven’t had any grip issues with it wet or dry. Now brakes in the wet, that’s a different story.
Re: Rear Tyre Size
Thanks, Ivan.
Re: Rear Tyre Size
Rear 30 PSI
Front 16 PSI
Front 16 PSI
Re: Rear Tyre Size
Thanks, Richard.
