Electronic timing.
gavmel
Electronic timing.
Post by gavmel » Wed Jan 22, 2020 12:24 pm
One question for the forum. I fitted a Lucas Rita, what do people use these days?
Gavin MacBain Meldrum
Guzzi power! V50 MkII, V7 Stone, Sportie 1100 i.e. & Audace 1400. Triking Mk1 850.
Re: Electronic timing.
Post by Weg » Wed Jan 22, 2020 5:53 pm
I've successfully used Electronic Sachs on both my 1100 ex fuel injected Calli, 1997 I believe, and the 750 in my Pembleton.
https://www.elektronik-sachse.de/shopsystem-3/en/
Easy fit, trouble free, adjustable advance curves. Check them out for your model.
gavmel
Post by gavmel » Wed Jan 22, 2020 6:50 pm
Many thanks. The Guzzi club forum and Facebook page occasionally makes mention of those. I maybe need two. My V50 has the old Bosch ei system which is possibly coming to the end of its life. I’ll wire up the Rita initially to see if it still works first.
Post by Throwley » Thu Jan 23, 2020 7:43 am
Despite being aware of the backfire issue, I chose Silent Hektik to run on my Guzzi (Triking still has points but I have plans...). It's a beautifully-made system and the customer support was superb when I had issues during the fitting, which turned out to be an out-of round stator bolt head! Easily upgradeable to twin-plug, too, should the finances ever arise. It has made starting marginally better and improved the pull in the mid-range but it's hardly noticeable TBH.
Sachse seems to be the system de rigeur nowadays; I'm not sure what the price difference is to the Sachse system, but I'll be going for the cheaper of the two next time.
