New build teething issues
mplayle
Re: New build teething issues
Post by mplayle » Thu Sep 18, 2025 9:13 pm
I did some diagnostics on the taillights today.
1) I tested the hydraulic brake light switch in isolation. It does work, but takes a lot of pressure on the pedal to activate it (more than I was trying yesterday). Light braking will not activate the switch.
2) I put a temporary manual switch in place of the hydraulic switch and tested the rest of the wiring (after tracing to make sure all was wired correctly). The brake lights worked fine. It turned out the low intensity (running light) filament of the left taillight had gone out - again. It had done that when I first picked it up and was getting the demo drive. I put a fresh 1157 bulb in and it all worked fine.
3) I noted the ground tabs in the tailight sockets are not anchored to the socket base, which might explain why the left rear running light keeps going out.
Next plan:
1) I am going to work out converting from the hydraulic brake switch to a pedal activated mechanical switch. I want the brake lights to work with light braking as well as heavy braking.
2) I have ordered a replacement flasher unit for using with LED turn signal bulbs. I have also ordered LED equivalents for the 1157 brake/running light bulbs.
3) I am going to dig through my assortment of screws and find the size appropriate to properly anchor all of the ground tabs in the taillights.
mplayle
Post by mplayle » Fri Sep 19, 2025 10:04 pm
I got #1 and #3 from yesterday's "plan" accomplished.
The new switch works very nicely - light braking turns on the brake lights and the pedal return turns them off. The new switch seems vulnerable to being hit by the bottom of my foot, but it actually is not. My normal foot angle leaves lots of clearance.
I am just waiting for the bulbs and flasher unit to arrive to take care of #2. They are scheduled to arrive Monday.
mplayle
Post by mplayle » Sat Sep 20, 2025 7:11 pm
The parts came in early, so I got to finish up the task list today.
I am happy with the results so far. I hope to get at least one test drive in before next weekend. There is a "cars & coffee" event about 70 miles away that I regularly attend in my Mini. I am hoping to be confident enough in the Triking's behavior to make that event as a "public debut".
The 40 mile run I did on Wednesday did instill confidence in the fixes for the oil out the breather issue.
mplayle
Post by mplayle » Sun Sep 28, 2025 8:49 pm
I did not get the test drive in during the week, but decided to just "go for it" and took the Triking to the "cars & coffee" event. It is about 70 miles away (so about 140 miles round trip). I met up with a friend part way there and he followed me in his classic Mini. We often do this event together in our Minis.
The Triking made the drive there and back just fine. It got about 30mpg (US) on the run. I let it cool down after getting home then went out and checked the secondary oil catch can - the dipstick was still totally dry! I also checked the oil level and it is still where it should be. I am satisfied the oil breather issues have indeed been fixed.
I am much more confident in doing longer runs with it now. I have a couple of special car shows coming up the end of October and beginning of November. I was planning on trying to take it to those shows and now have good confidence I can drive it to the shows (weather permitting).
Post by Richard and Pat » Sun Sep 28, 2025 10:46 pm
Great news, well done.
mplayle
Post by mplayle » Mon Sep 29, 2025 1:49 am
My friend, Bruce, took a brief video along our way home.
https://www.youtube.com/watch?v=8EHM_YD7WbA
mplayle
Post by mplayle » Mon Oct 27, 2025 4:44 pm
I have gotten more drive time/miles on the Triking (her name is Betty) and figured I should post an update. I have put on about 370 miles since getting everything settled.
Almost all the electrical gremlins are solved, just a small annoyance with the signal for the speedometer getting noisy if the headlights are not turned on. I prefer to be seen by traffic, so run with the headlights turn on, so I don't consider it an issue anymore.
The secondary oil catch can is doing the job. When the original breather was not draining and puked out about a quart of oil, I topped up with a full quart, so was slightly over-full. Over the 370 miles, a few ounces have been caught by the secondary catch can that I checked and drained today. I also checked the main oil dipstick and it shows (or still just over) full, so I suspect it is the over-fill that has gradually been caught by the secondary catch can. I will continue to monitor the oil situation.
