Red ignition lamp
Red ignition lamp
Post by Richard and Pat » Fri Aug 08, 2025 5:27 pm
The red ignition lamp is intermittent on switching on prior to starting the engine.
When it does deign to appear it goes out immediately on the engine running.
New alternator and new regulator.
Regulator earthed direct to battery.
iant-s
Re: Red ignition lamp
Post by iant-s » Tue Aug 12, 2025 2:01 pm
It is supposed to go out as soon as the alternator is turning.
Have you used a filament lamp? An LED won't work.
Post by Richard and Pat » Tue Aug 12, 2025 7:21 pm
It does go out on starting Ian. When first switching on sometimes it lights and sometimes it does not.
iant-s
Post by iant-s » Wed Aug 13, 2025 3:19 pm
Presumably an electronic regulator with one of its wires specifically to work the charging light. Oddball fault then. When it does come on, does it flicker if you shake the wiring about? (thinking a poor connection).
Have you had a good voltmeter across the battery and seen 13.8v to 14.1v with the engine running?
Post by Richard and Pat » Sun Aug 17, 2025 7:06 pm
Sorted when I found a dry joint from regulator. Thank you everyone who offered help.
