Engine hesitation
Chapin1
Engine hesitation
Post by Chapin1 » Thu Aug 21, 2025 10:31 pm
Just getting my T4 on the road , my engine is a 1200 cc 2016 8 V from a stelivo. It is fuel injected and I’m running 40 psi (2BAR) when talking off or cruising when I accelerate it has a hesitation very noticeable, any suggestions? No motoguzzi dealers within reasonable distance.
Mike wooops 2.78 bar
Re: Engine hesitation
Post by Throwley » Fri Aug 22, 2025 9:49 am
2016 Stelvio had roller tappets, so it's not that.
is that with the engine hot or cold?
What air intake system are you using?
It can be a symptom of poor injector spray pattern caused by gummed-up injectors, maybe give 'em a clean and try again.
Archie
Post by Archie » Tue Aug 26, 2025 11:25 am
Try a TPS reset
Davyboy
Post by Davyboy » Wed Aug 27, 2025 10:25 am
Hi, If you mean a pronounced "flat spot", in my case between approx. 3-4k rpm, then I found the problem to be in the exhaust. On the bike they use twin short pipes into one silencer, but on the Triking two separate long pipes are used with, in my case, "straight through" boxes.
I found that fitting "decibel breakers" into the pipes just as they enter the silencers to give a slight back pressure gave an improved resonance in the pipes and the problem was completely solved. Happy Days!
If you choose to try this I can supply you with with dimensions.
Regards Dave
Chapin1
Post by Chapin1 » Thu Aug 28, 2025 4:32 am
Yes Dave I would love to get the dimensions I'm using the Norton style silencer I would assume they would go ahead Of the silencer
Mike
Davyboy
Post by Davyboy » Thu Aug 28, 2025 1:54 pm
Hi Mike, Yes, they fit into the ends of the pipes prior to fitting the silencers. This also is assuming you have space in them to allow the gasses to flow.
It would be easier to communicate by e-mail. Contact me on dave.richards54@yahoo.co.uk
Chapin1
Post by Chapin1 » Wed Sep 10, 2025 6:15 pm
Thank you Davyboy as I put the silencers and whoope they worked no more flat spots. Thanks again
Mike
