Extending Type 4 HT Leads
Post by peakrock » Wed Jul 16, 2025 6:40 pm
I need longer HT leads for my Type 4 build which I can probably do myself by carefully removing the "threaded" stud clamped to one end of the HT lead and passing a new copper cored HT lead through the hole and soldering it on. The other end that goes into the coil I can also do with careful use of various pliers etc. However, it's only a passable job so I was wondering if those of you with Type 4's had found somewhere that can make up new leads or did you discover a way of doing them yourself?
Thanks Dave
MarkG
Re: Extending Type 4 HT Leads
Post by MarkG » Wed Jul 16, 2025 11:01 pm
I extended mine by using NGK HT lead connectors
https://www.johnleemotorcycles.co.uk/pr ... connector/
It was some years ago and so I can't exactly remember how.
If needed I can check. My engine and coils are 8V Stelvio
Post by peakrock » Fri Jul 18, 2025 9:40 am
Thanks - I didn't know HT lead connectors like that existed :D
