Windscreen washers
Robmason
Windscreen washers
Post by Robmason » Thu Aug 04, 2022 10:00 am
For those who have wipers fitted to your Triking:
Do you also fit washers? I can't see any obvious ones fitted in the various photos
If not, how do you manage the annual UK MOT?
Rob
Re: Windscreen washers
Post by peakrock » Thu Aug 04, 2022 2:33 pm
Hi Rob
You'll need washers for the MOT. I've done mine with an electric pump and long hose to a nozzle on the bonnet. The long hose enables you to lift the bonnet up and detach the hose from the nozzle - it's a plastic hose so easily pushed on and off. I set mine some distance along the bonnet as I used a single fitting with two outlets. Close up below to show the nozzle on my old Triking.
Post by Weg » Thu Aug 04, 2022 6:49 pm
Rob
Definitely fit washers.
When you get sprayed with road filth you will need them.
I fitted a generic electric unit with 2 nozzles. Switched on the dash with 2 position switch. Wiper, wash/wipe.
Robmason
Post by Robmason » Fri Aug 05, 2022 11:02 am
Thanks for the tips. I was thinking of using "on arm" washers but the ones slightly angled under the wiper arm look a good solution. Fortunately I have nearly 3 years until the first MOT!
Rob
Post by Weg » Fri Aug 05, 2022 11:28 am
You may well need them well before the mot is due :idea:
Post by Throwley » Mon Aug 15, 2022 9:27 am
From the MOT manual...
You do not need to inspect windscreen wipers on vehicles with:
an opening windscreen
some other means of giving the driver an adequate view through the windscreen to the front, left and right
From Construction and Use...
Windscreen wipers and washers
34.—(1) Subject to paragraphs (4) and (5), every vehicle fitted with a windscreen shall, unless the driver can obtain an adequate view to the front of the vehicle without looking through the windscreen, be fitted with one or more efficient automatic windscreen wipers capable of clearing the windscreen so that the driver has an adequate view of the road in front of both sides of the vehicle and to the front of the vehicle.
(2) Save as provided in paragraphs (3), (4) and (5), every wheeled vehicle required by paragraph (1) to be fitted with a wiper or wipers shall also be fitted with a windscreen washer capable of cleaning, in conjunction with the windscreen wiper, the area of the windscreen swept by the wiper of mud or similar deposit
Might be just a Type 1 thing, but testers have judged that they have adequate view over the screen, so don't look at the wipers or the lack of washers on mine.
Crozier3
Post by Crozier3 » Mon Aug 15, 2022 10:00 am
Hi all,
On my trike I started with Brookland screens which were useless especially in Scottish weather!!or when being washed by an artic unit. :lol:
I then fitted a wind deflector that allows me to look over to see the road and dodge behind in very heavy rain. I also have end defectors to deflect wind birling round the ends.
The MOT man is quite happy and passes it without comment. :)
Bill
Robmason
Post by Robmason » Mon Sep 05, 2022 3:16 pm
If anyone was interested, attached photo shows screen washer fitted to T4. Works reasonably well and the washer design allows lots of adjustment to the jets. Thanks Tony for the idea.
Post by Weg » Tue Sep 06, 2022 7:09 am
Where is the picture Rob?
Email it to me if you are struggling to attach.
