Hi there,
Does anyone out there know what size the fittings are on the oil cooler hoses. I’ve read there are various available and they are notoriously difficult to determine type by simple measurements.
Would take the guess work out of it if someone already knows!
Thank you
Oil cooler hose fitting size?
Re: Oil cooler hose fitting size?
Hi Colinc,
If you have Fadebook [sic] try a question on there too see which comes back quickly. Sorry I cannot help myself only T3 here. https://www.facebook.com/groups/156599248504621/
Hi Colin,
'Scuse the vagueness but it is a while since I plumbed in the oil cooler. I seem to remember that the Guzzi pipe fitting was an unobtainable size, but the adaptors screwed into the cooler were a standard thread so I replaced the adaptors with standard AN adapters and used the self-assembly AN fittings and pipe. -6 or -8 would be an appropriate size. Choose the pipe carefully because the oil temps can be quite high on the 8V engines.
John
John
Thanks a John. What you said makes complete sense. Much appreciated
Richard and Pat wrote: ↑Tue May 12, 2020 10:05 amHi Colinc,
If you have Fadebook [sic] try a question on there too, to see which comes back quickest. Sorry I cannot help myself only T3 here. https://www.facebook.com/groups/156599248504621/
