Gear ratio
Chapin1
Gear ratio
Post by Chapin1 » Fri Feb 27, 2026 9:44 pm
Just finished a T4 not happy with first gear it’s way to tall and with hills where I live Ill burn out the clutch. I used a 2016 Stelivo 1200 cc donor bike. The forward reverse transmission works great in reverse as its ratio is perfect . Wish forward was same as reverse ratio, anyone know if this transmission cans can be modified?
Michael
iant-s
Re: Gear ratio
Post by iant-s » Sun Mar 01, 2026 5:42 pm
You need the 15 inch rear wheel conversion from Triking. Its not cheap but will massively improve your car. Lowers the overall gearing and you can fit a car tyre which will be way better than a round profile bike tyre which drifts and follows every nuance of the tarmac. Also car tyres are way cheaper than bike tyres.
louise
Re: Gear ratio
Post by louise » Fri Mar 13, 2026 2:58 pm
The first gear in the Stelvio transmission is designed for a motorcycle’s weight and gearing, so in a T4 it can definitely feel tall. From what I understand, the gearbox ratios themselves aren’t easily changed without major internal work. Some builders solve it by altering the final drive ratio or wheel size instead.
