Indicator positions
Wizzle
Indicator positions
Post by Wizzle » Fri Sep 29, 2023 7:06 pm
Evening all
As the evenings draw in I’ve started designing the wiring loom whilst I (impatiently!) wait for my kit to arrive.
I’ve seen a few Trikings and other reverse trikes with Lucas-style torpedo lights (eg Lucas 1130) on the front wheel arches. Is that acceptable for the MVSA? I see most are attached to the side of the headlight, which is obviously one less wiring challenge, but I’d be interested to know if it’s an option?
Re: Indicator positions
Post by Weg » Sat Sep 30, 2023 3:26 pm
Both positions are ok for msva.
I've put indicators on the mudguards, hid the wires in a stainless tube tacked to the under edge of the mudguard bracket then up the underside of the guard. 2 wires needed.
If you haven't already got a copy, worth downloading the msva manual. So many things to check on. https://www.gov.uk/government/publicati ... ion-manual
Wizzle
Post by Wizzle » Sat Sep 30, 2023 5:21 pm
Brilliant, thanks Tony - routing the wires was my next question!
I did rummage through the MVSA but could only find references to heights / distances, so that helps a lot. Thanks!
Post by Weg » Sat Sep 30, 2023 6:54 pm
The magic tube.
Cable then glued with black stuff to mudguard and up to light.
Wizzle
Post by Wizzle » Sat Sep 30, 2023 11:14 pm
That’s an elegant solution, thank you!
Post by Richard and Pat » Tue Oct 03, 2023 11:27 am
This was my solution using the same lamps as the Type 1's and giving a good clear signal.
Wizzle
Post by Wizzle » Tue Oct 03, 2023 8:40 pm
Another elegant solution! Thank you!
Post by Richard and Pat » Wed Oct 04, 2023 5:07 pm
Thank you.
I shortened the Headlamp mounting post too so no threads showing below nut.
Wizzle
Post by Wizzle » Wed Nov 06, 2024 4:52 pm
Sorry to dig this up again Tony, but I'm finalising my loom and can't make up my mind how best to run the cables from the mudguard / sidelight back to the chassis - I'm trying to find the path that needs the least flexibility or movement. How did you get the wires from the mudguard back to the chassis if you don't mind me asking?
Regards
Alex
Post by Weg » Wed Nov 06, 2024 6:59 pm
Alex
My picture of 30 sep shows a s/s tube to tale 2 thin wall cables, indicator and ground. Don't rely on chassis / suspension for earth.
I then glued the cables to the outer edge inside the mudguard with black PE adhesive, not in direct path of debrit from tyre.
Hope this helps.
