Windscreen washers
Robmason
Windscreen washers
Post by Robmason » Thu Aug 04, 2022 10:00 am
For those who have wipers fitted to your Triking:
Do you also fit washers? I can't see any obvious ones fitted in the various photos
If not, how do you manage the annual UK MOT?
Rob
Re: Windscreen washers
Post by peakrock » Thu Aug 04, 2022 2:33 pm
Hi Rob
You'll need washers for the MOT. I've done mine with an electric pump and long hose to a nozzle on the bonnet. The long hose enables you to lift the bonnet up and detach the hose from the nozzle - it's a plastic hose so easily pushed on and off. I set mine some distance along the bonnet as I used a single fitting with two outlets. Close up below to show the nozzle on my old Triking.
Post by westendguzzi » Thu Aug 04, 2022 6:49 pm
Rob
Definitely fit washers.
When you get sprayed with road filth you will need them.
I fitted a generic electric unit with 2 nozzles. Switched on the dash with 2 position switch. Wiper, wash/wipe.
Robmason
Post by Robmason » Fri Aug 05, 2022 11:02 am
Thanks for the tips. I was thinking of using "on arm" washers but the ones slightly angled under the wiper arm look a good solution. Fortunately I have nearly 3 years until the first MOT!
Rob
Post by westendguzzi » Fri Aug 05, 2022 11:28 am
You may well need them well before the mot is due :idea:
