Cali 3 rear brake rotor
Post by Doverhay » Mon Apr 01, 2024 3:55 pm
Can anyone tell me what the PCD of the 5 rear brake rotor fixing bolts are? It’s a difficult one to measure accurately, I’ve come up with either 110mm or 112mm but I need to be accurate to find a replacement.
Re: Cali 3 rear brake rotor
Post by Richard and Pat » Fri Apr 05, 2024 10:21 am
Have you tried the Guzzi Owners club on FB Richard?
Post by Doverhay » Thu Apr 11, 2024 7:45 pm
Al says it’s 112mm, I’m going to remove the rotor and check the alignment before going any further. The rotor I have is quite a thick one so it’s not likely to be buckled but may need refacing.
