Triking T3 2019 Factory Built
Post by westendguzzi » Sat Jul 20, 2019 10:23 am
TRIKING CYCLECAR. TYPE 3 SPORT.
REGISTERED APRIL 2019. To be sold on behalf of the owner as a private sale.
All interest to be in writing and submitted for owners approval to Alan at Triking.
This is a rare opportunity to acquire a very high specification Triking cyclecar professionally built with a “ FB” (Factory build) annotation to the chassis number. MSVA tested in late 2018 and DVLA first registration in April 2019. The vehicle has only covered appx 500 Miles for initial shakedowntesting and has just had its 500 mile inspection and service at the Triking factory.
Engine installation is a 2004 model Moto Guzzi 1100 EFI ( PI) donor with a Moto Guzzi 5 speed sequential gearbox which has been refurbished at installation including mild port polishing for improved gas flow. Bespoke ECU Triking mapping installation. New clutch assy. Specification above the standard built Triking and comprehensive upgrades include, Nova in-line reverse box assy, metallic silver powder coated chassis ,uprights and wishbones etc. Mercedes Iridium silver metallic paint work, stainless polished engine breather/ separator, K and N free flow air filters, bespoke car and integrated ECU wiring loom, Triking polished alternator cover and polished valve rocker boxes, stainless front wheel rims on polished billet hubs with stainless spokes, performance Heidenhau front tyres, upgraded front brakes with cast discs and AP racing type callipers with road/ race pads, stainless brake flexi hoses, bespoke bonnet Louvres, Triking touring windscreen with wipers and washers, Hagon adjustable front suspension, polished stainless side heat shields, stainless exhaust system with bespoke Triking stainless silencers, Triking stainless luggage rack, 15” modular rear wheel with car tyre and lightweight hydr/ mech. Calliper, premium range Muirhead Claret leather trim with map pockets/ tunnel top fluting and matching 3 spoke steering wheel mounted on Triking billet steering hub with QD splined boss, Red matching Carpet set with bound Red edging , Billet Alloy Triking gear knob set, Triking 3 piece antivibration mirror set, Bespoke Triking instrument set with integral warning lamps and Triking logos, Aircraft grade alloy dash with engine turned finish and alloy bottom trim, billet turned toggle switch covers, locking glove box, 12v aux socket wired for battery maintenance charging, Stainless steel fuel tank, Tonneau cover in Red double duck material . Triking orientated Cherished registration no. Stainless front number plate surround, Rose jointed / tunnel mounted gear change, Monza typefuel filler, Hagon adjustable rear suspension, Billet turned alloy exhaust header roses, Stainless nut and bolt set throughout build where appropriate, 30a(320 cca) sealed zero maintenance AGM Battery and master kill switch.
Outside car cover with slight damage to front. This is probably the highest build specification Triking ever built and would suit the discerning owner who requires the very best.
Worldwide shipping available at cost.
Purpose built hydraulic tilt bed trailer by separate negotiation with owner if req.
All enquiries to Triking Sports Cars ltd. 01953 850044 enquiries@trikingsportscars.co.uk
